The Anafi has a lot of sensors, including a Barometer (that is set to ‘0’ when taking off from the ground... not sure of its setting when hand launching...), a GPS, a buzzer somewhere inside the guts of the bird (but not on the bottom of the Anafi) that beeps when you lose your drone and click on the ‘bell icon’ displayed on the top right corner of the map in FF6, an accelerometer, a magnetometer...
On the bottom you have 4 ‘things’ : The blue LED, the Cooling fan, the vertical camera, an Hybrid UltraSonic Sensor (proximity sensor that usually get distances in short ranges such as 0,2 to 4 meters). Contrary to the DJI drones that have 2 components to emit then detect proximity, the Anafi has a single hybrid component (see pix below)
The hand landing is a kind ‘software based’ mixture that takes into account informations coming from all the sensors.
The trick is to understand how this software interprets ‘I have my hand just below your @ss, you can land and cut the motors...’
The problem is with each release and modification of FF6, to guess the change they made on ‘how to hand land’...
