I thought I'd share this as it really has turned out to be an effective and cheap way to get better FPV and range out of the Anafi. I took a metal colander and removed the base and handles so it was just the bowl. I then cut it in half with a sawzall, made a notch for the controller, and attached a hinge one end and a clasp on the other. The two metal pieces you see on coming down off the back line up with each side of the controller handles. So once you attach your phone underneath and throw a rubber band around the bottom it's solidly in place. It doesn't budge at all. Then I used aluminum tape to cover the whole thing. All combined it was less than $40. It takes all of 5 seconds to take on and off as well.
I'll do some more testing, but based on previous flights from the exact same spot I'm seeing an increase in range of at least 30%. More importantly, I'm getting MUCH better FPV in areas with tons of WiFi interference which is where I fly 80% of the time. Here's a video where I got the Anafi out to 2 miles with no loss of FPV and plenty of WiFi signals to battle. I could have gone plenty further but didn't see the need to push it. At the end there's a short section of what it looks like with the controller attached.
If you have more questions about it, let me know. But I thought I'd share a simple, cheap and not-warranty-busting solution to help with connectivity.
