Hello
I have been waiting in vain for Parrot to reply to a case I logged with them a week ago: Can somebody explain to me what four red LEDs blinking in sync means on an Anafi smart battery, please.
Here's the long version of what happened:
I had not been using a fully charged Anafi smart battery for a couple of weeks and understand that it is meant to go into hibernation, but mine seems to behave differently from how the Parrot website describes it: One morning I woke up and all four LEDs on the spare battery were flashing in in sync in red. I have not been able to stop this by recharging the battery, neither by connecting it to a computer USB port nor to main mains power supply.
This is what I have tried so far: I read online that you are meant to hold the power button for 15 seconds in order to switch the blinking LEDs off. When I do this, they indeed stop blinking red in sync and briefly go through two cycles of individually blinking green, but then revert back to blinking red in sync.
I have tried to hold the power button for longer, approximately 30 seconds. This has stopped the LEDs blinking after 15 seconds and they did not come back on after the full 30 seconds. However, after a couple of hours connected to a mains power supply (during which there was no LED activity at all) I held the power button down to check on the charge: This only triggered the four LEDs to flash red in sync again.
When nothing seemed to make a difference and Parrot did not reply to my case I left the battery on my desk with the four LEDs flashing in red. After three days the LEDs stopped flashing. I assume that the flashing used up the remaining battery charge. Pressing the power button indicated that there was no charge left as no LED lit up at all. I then reconnected the battery to a charger. The LEDs started flashing green in the normal way they should when being charged.
After a few hours the LEDs indicated that the battery was fully charged by having four solid green LEDs.
I then inserted the battery in the drone and tried to power it on.
Unfortunately, the battery went straight back into displaying four red LEDs flashing in sync without powering on.
It would seem pretty obvious that four red LEDs are meant to indicate something bad, but I am really surprised that this is not documented on any Parrot website that I have found.
