Hi
I happened to remove the Anafi battery shell . It had an issue where if I feather touch the battery case, the unit would switch ON & OFF . I realized the issue was with the deformity of the case and nothing to do with the switch.
Anyone interested to take a peek into the Anafi battery case....attached battery pics ...The cell is 7 cm long( single cell) x 2 cm thick( 2 cells put together) in dimension stacked one above the other. It was very easy to remove without having to break anything. It was simple glued ! Just use a good sharp edged blade/knife to scar along the line edge of the shell case.
