- Joined
- Jul 16, 2019
- Messages
- 14
- Reaction score
- 0
So I finally had my first crash today. Was doing some flying for fun in a park and I flew my Anafi into a light pole. I had my directions reversed and should've moved the stick the other way. At first glance it looked like all I would need to do is replace Arm 3 and possibly Arm 4. I was prepared to buy the full Mechanical Kit since I really needed the parts before next week. Once I got home and powered on the drone, the camera gimbal appears to be damaged also.
The camera won't center during startup. It does its usual startup sequence, but at the end it points down at almost a 45º angle. It will make a few more attempts, but it never ends up straight. I can't even control the camera with the controller or directly from the app. I'll get the "Camera Error - Check that nothing is blocking the camera, then restart you drone" message if I hit FLY. If I select the drone, then the camera is highlighted in red. When I hit Camera Calibration the Gimbal Calibration is "Unavailable."
I'm going to guess that the camera gimbal is hosed and this isn't really repairable or if it is it would be cost prohibitive.
