The anafi recently crashed and repaired the upper right arm. Height and distance to controller telemetry is off by a couple of feet. Spun re calibrated so the anafi flies as it should and re calibrated controller, but is reving with no thumbs on sticks, my guess is that one of the arms is over weight after gluing, and the actually rev is the drones computer compensating for the added weight on that one arm. It is also yawing to the left slightly(compensating for glued heavy arm?) with no stick input. Anafi weight with glue added after repair and without battery is 190 grams is this the correct factory weight? Thoughts on yaw and telemetry distance being off?
