I have only had my Anafi for a couple of weeks so far and a few days ago, decided to use the FlightPlan feature. I setup a course that was to take about 3'40" to complete, in open fields, away from obstacles, power lines etc and having carried out all the usual pre-flight checks, set the FlightPlan running. I should also point out, that I have flown in this location twice before without any issues (but not using FP).
I suppose due to being relatively new to the FF6 app, I had set the Geofence limit to 500 feet distance, 200 feet altitude - unfortunately the FlightPlan exceeded the 500 feet distance and flashed up a 'Geofence Reaching' red warning (the route took the Anafi 650 feet away).
I read in another thread on this forum of a similar situation happening, whereby the member initiated the RTH function in panic and ended up losing his drone. In my case I also initiated RTH and the Anafi sucessfully returned to the RTH position - but this is where the strange behaviour of the drone began!
It hovered above RTH for a while, then began to take off in the opposite direction from which it had returned from the FlightPlan route? I pressed cancel RTH, then re-initiated it - same behaviour occurred again. I managed to stay calm and manually attempt to land the craft - (pulling back on right stick to bring it back and then back on left stick to bring it down). This worked for a while, until the Anafi stopped moving momentarily, then again decided to take off in the same direction as before. I should point out that at this stage, I was still holding down the sticks.
Now I was actually starting to really panic, as it appeared that my control was somehow being overridden? I let off the sticks and reapplied manual control again and the drone started to return - but the same situation (as just mentioned) reoccurred.
I persevered for a while, trying to regain control of the craft, mindful of the fact that the battery was now starting to get low (20%).
Eventually, I was able to return the Anafi and land it safely, but the experience left me quite disturbed as to why this behaviour had happened in the first place.
I have tried to analyse it and also attempted to look at the flight data (I know there is a way/method to view very detailed flight statistics, but have no idea of how to do this).
My original thought was that on first initialising RTH, following the Geofence warning - I had not cancelled FP mode and gone back to Manual mode option, so the Anafi was constantly trying to fly back to the end point on the flight plan (where it is set to hover, pending further instruction - as I understand it?)
Beyond this, I am at a total loss as to what really happened, but I would obviously like to find out for certain, so that any omissions (if any) on my part can be avoided in future.
If anyone can throw any light on this, I would be most grateful?
Thanks in advance!
Thanks in advance!
