Anafi unstable and lot of noise
BoomerXL
Netherlands
Hi all!
Couple of weeks ago I crashed my anafi from just a couple of meters high. Gimbal was bend which caused an error during startup because it got stuck during calibration. I managed to fix this by sanding of a bit if the camera housing.
Drone is flying again but seems very unstable and the buzzing seems much louder then before. Especially when descending. The crash was on his gimbal and right front motor (on the beach, so relatively soft crash). The axis of the motor seems to have a very very small movement which I do not find in the other motors. Can this be the cause? Does anybody have tips to check what can cause the noise?
I did not replace the props because the all look fine.
Thx!
Thx, I
On the beach?
A single grain of sand could partly block the motor.
Perhaps try with compressed air.
thx, I will try. Although no visible grains of sand and it rotates by hand the same as the other motors. Only thing I notice is there is no tolerance in the other motors and a tiny little bit in the front right.
can I disassemble the motor from the arm easily? I do not see any screws.
guads100k
