- Joined
- Sep 1, 2018
- Messages
- 346
- Reaction score
- 136
In case anyone is having issues, USB port loose or breaking off it can be repaired if no warranty is available.
Bebop 2 Skycontroller 2 has issues with the USB port breaking off, I’ve repaired a couple of controllers in the past. Skycontroller 3 can experience the same, if you’re handly with a soldering iron you can repair this.
Just be careful, disassemble SC3 until USB port is assessable. Carefully separate USB mini board from charge port board, they will separate after removing complete assembly from housing. Resolder these anchor connections holding USB port to mini board, only at these two connections as shown in the picture. A dab of epoxy on both sides of USB won’t hurt, after soldering these two anchors.
There are also four pins soldered to the mini board, these provide signal to and from phone. If any of these are broken, resolder but extreme care each of four pins must be separate from another.
Also included picture of On/Off switch, in case anyone is interested how the antenna door activities the on/off feature.
Good luck, wishing everyone the best with repairing problems like this USB port issue.
All the best,
Paul
All the best,
Paul
