Anafi vertical camera failure message
idea3
Hi
I am new to this forum. I've noticed a few threads on this subject, but no real solution. I am hoping things progressed and someone found a good solution for it. I dropped my drone from about 1m. yesterday. All seems to be fine. Cam is working and it even levels after restart, but I have this message and the drone will not fly. I tried resetting it. I tried recalibrated the drone (not camera), but to no avail. Any suggestions?
I am on a trip, so can't open it and see if inside is all good.
Thank you for any help... :)
Thank you Augustine. This is exactly it. It was not even that hard. Around 1-1.5 m but on concrete. Touched the wall, while landing.
Augustine, is it all about tiny smart pixel sensor, or smth on PCB?
any why this part is so sensitive for crash/hard landing? it doesnt look damager, and i know that so small sensors usually are quite hard to crash, so maybe its smth on pcb?
tia
I had this when starting my drone first then the SC3. The problem went away by starting the SC3 first, then the drone.
Hello,
I've got the same message...and no vidéo returne anymore ...
I wrote to Parrot and wait for answer.
If there is something to do by myself without the Parrot support, it could be great... so an idea ???
Thanks,
mikerose88
