- Joined
- Mar 12, 2020
- Messages
- 20
- Reaction score
- 3
Hello
2-3 Hours of testing ... enough seen !!!
How can a manufacturer develop such a product, leave it in the hands of users, with so many bugs, lack of ergonomics, checks, etc., etc.
When I started reading here before buying, I should have been more careful. I said to myself oh ... we'll see!
Ok I am starting, this is exactly how we test a product.
Give it to a "donkey" ... like me! (may be)
I have programed in C / C ++ in the past. Often the most difficult is to be wary of "input" errors ...
From the first attempts, as "photographer, videographer (amateur)
I quickly found that the ergonomics, as well as the settings were not thought "videographer"! Clearly it is thought for YT!
It reminds me of the Sony Camera, Olympus sometimes ...
Then...
Are there beep tones to prevent such or such actions?
Are there any checks to confirm this or that order?
... apparently not!
Admittedly, I know little about this product.
On a table, outside the drone ready to take off if necessary active.
I go into the house, try some video settings, the drone camera was perfectly controllable ...
but, the smartphone falls on the table because badly fixed (fixing totally badly designed)
The wire disconnects. I bought a Cubot Quest (ip68) for the outside and supports the water.
little Boy but works quite well!
I have, I think I closed the cover of the radio control!
I open it again, plug it in, no connection.
Exasperated, I close everything, but I forget for a moment the drone ...
I'm going out (-8 meters) but ... where did it go? It was no longer on the table, but 1 m above it.
He had taken off! Huh? How? 'Or' What ?
Fortunately it was stable, stationary-fly
I grabbed it with my hand, tilted, it's cut. Very well!
What did i do? What mishandling? No idea ... but how did it take off? Did I inadvertently press something ...
If so, not a beep, not a confirmation request. Nothing!
Anyway, this should NEVER happen!
Later on a table, in order to learn the video settings, as said, totally wacky as it is designed,
here is that suddenly I lose the connection no more images. Well?
I'm trying to reconnect, nothing! I try to turn off the Drone, the fan kept spinning, no LED on, Nothing.
I remove the battery, wait 10 seconds, reassemble it, and voila that the fan turns again,
I press the buttons, the drone performs a reset ... and finally I was able to stop it ...
To put the drone in function only a brief and small press on the button is enough ???
It should NEVER be done like that either.
I also have a problem with the FPV function, does not work (?)
In short Excuse to say "what a beautiful bazaar" !!!!!
So there no. By reading here and there, what can still reserve me as a surprise,
the days when I intend to use it in practice `?
Honestly, what to do with such a product?
Sorry I totally lost confidence in the concept!
I plan to activate the RTS function
(Return To Seller)
Sorry!
Honestly, I was so happy to use this model!
No, not so.
Sincerely, François
PS
The first automatic and standard video cameras tests ... and by comparison with a cheaper product ...
that one, gives us a better picture ....
Between what we see on the web and reality ... wouldn't there be a little bit of a lie?
Then...
... apparently not!
(Return To Seller)
Sorry!
No, not so.
Sincerely, François
PS
