It worked I got OEM props and it flys great never buy aftermarket props thanksI got that until I replaced the props. Might help you also. Might not but worth a try.
Can you please tell me what exactly is going on with your drone, when i take off mine it goes up and down, its not steady and when i take it down it goes hard to do ground, and om screen there is warning strong vibrations, check all props... Really frustratingOn my anifi I keep getting tighten motor screws warning and it not stable it bounces around even after I tightened the screws all the way around the drone still bouncing around
I have, the origins and i think two or three of third parts, i dont have here to buy it, need from ebay it takes long and im not sure which of them are original.Have you replaced all the props? You probably have an unbalanced pair of props.
