Battery replacement
Rio
Hi there!!! Ultraserious question: may I use a 2500mAh/27Wh/11.1V as a replacement for a 1200mAh/13.3Wh/11.1V on my bebop parrot 1?? Is there any risk?
You can as the drone can fly with the extra weight. You need to take care as the drone ascents slower and during flight, the stop time needed (and the distance) will be doubled. By the way chinese 2500mAh batteries are not actually 2500, flight time will be increased a couple of minutes only (due to extra weight) if you are lucky.
lustar
