Bepop 2
I had this issue also, make sure you're in airplane mode, and wifi is on. Once you power on your drone select it from the wifi settings, it will read Bebop@#@#@# or whatever else the numbers are. It will say no internet connection which is fine in the wifi settings. Then start your free flight pro program. You should already have it installed. It should connect after that.
Viking
