- Joined
- Aug 14, 2019
- Messages
- 168
- Reaction score
- 21
I am hasty to turning the drone or the battery itself on by the button as I assume we all are. I was looking at the Anafi's battery and was able to turn it on just by squeezing it in the palm of my hand, with all fingers wrapped around it. I tried and succeeded each time. This is bad news if a bird such as a hawk or eagles talon clutches it. The drone will shutdown in mid air everytime from this simple strike. I have not tested this idea to action, but my thoughts are that it well shutdown and fall. The talon strike is used every time and beaks are probably never used. There are no 3D printed parts or tape you can cover it with becasue that risks shutting off in air itself as well. A raised 3D part may work but adds weight. They should have designed it indented or incased such as mavic mini. But then with the mavic mini a smaller bird or bug could take that out.
Maybe the annafi could sense a bird or bug strike and do an auto return to home with that message for damage inspection, because as you know bugs will chase and birds will chase. In the spring some big bee common in North America (I think it's a carpenter bee will hover and go after anything flying plane bird anything in the air even. So getting out of the area would be ideal via autodetect.
-Object Strike detected: Returning to Home.
