Crash now no sd card error
ParrotAnafiFan
U.S.
questions:
is the drone still flyable if no sd card error is present due to a crash?
If you had this problem and fixed it what remedies did you use?
No tears are visible in SD ribbon to main board, you have to solder just to disconnect the ribbon sadly from the holder. (soldered metal bar securing it.)
SD card holder looks good all contact making contact with card
already tried reset same error.
card formatted to fat32 - same error
I have come to conclude that it is not the ribbon or connection under mb, but the entire square pcb that the micro sd sits on is warped. I will have to strengthen it and see it it works after that.
Still an SD error, there is no way I am going to unsolder all that crap just to plugin the connector again. I will have to fly without that ability.
gearsgood
