DIY Anafi "drone only" carry case
apixelpilot
San Francisco, CA
Myself and others have discovered that a simple, "drone only" case for the Anafi is nowhere to be found online. I was determined and came up with the following DIY. Enjoy!
I found this case for just under $12USD:
1. The case comes with a custom formed interior made for a different product.
Use a utility blade to cut along the top edge of the interior *** be careful not to cut through the shell.
2. I re-lined the inside with spongy shelf liner; avoiding the ends because it’s already pretty snug lengthwise.
3. To keep the drone from moving around I added foam pads to the sides to hold the “legs” in place.
4. Sealed the edges of the liner with hot glue.
I found a piece of black foam padding to replace the (found) green foam padding.
Used the green foam to create a bed for the gimbal, and a gimbal lock for good measure.
5. As snug as a bug in a rug.
The pix are numbered to follow the text and since and I’m taking pictures, I’ve included pix my kit (and caboodle).
gearsgood
