Effective, packable, inexpensive sun shade for Anafi camera
DroneSpeak CMS
I had an occasional lens flare while piloting and walking behind an Anafi along a trail among tall trees on a sunny day. I was not planning to rotate the camera up from horizontal. Later at a hardware store, I found 1/4" thick, 1/2" wide, dark gray, window/door insulation with mild adhesive on both sides. A thinner product would probably work. A short strip reduces overhead sunlight on the camera lens, which reduces lens flares. The foam strip's adhesive allows repositioning on the Anafi. As a bonus, the foam compresses easily, allowing the Anafi to be folded up in the carry case. Be sure to leave a shorter strip of the original paper on the underside near the camera, otherwise the foam will stick to it... however you can still peel it off the camera. Enjoy. Images attached.
What a clever idea! I will definitely emulate that! Actually, I think I will build one of plastic and velcro to make it easier to pack and remove.
Ritchh
