Hello!
New Anafi pilot from Finland checking if there's anyone familiar with this problem. Had and accident to my first anafi when i bumped it to door while carrying it. The L-bracket between gimbal motors got a small crack and bend into sharper angle than 90degrees which blocks the gimbal for doing check on startup. Tried to fix it, but L-bracket had very strong tension that kept the angle greater than 90deg. It was impossible to keep it straight.
However, got a new one from retailer while parrot checks this up and had a small aerial crash. No visual damage, flies just fine. But the L-bracket bended again into angle which blocks the gimbal moving the camera.
Anyone familiar with this? Wondering if this is a wider issue? Or anyone figured out how to fix this?
Below an image where the angle of camera and the drone itself can be seen.
