- Joined
- Feb 22, 2019
- Messages
- 116
- Reaction score
- 58
OK I have a little understanding about antenna basics but not how they apply to the Anafi or drones in general. I have disassembled my Anafi controller and it appears simple to remove one or both stock antennas, solder on new leads and to mount external connectors on the controller.
Please shed some light on how this drone works:
The two controller antennas, I am guessing one is 2.4ghz and the other 5.8ghz?
Does the controller constantly sample the two antennas/bands and use the stronger signal? Or does it use one band for drone control and the other for receiving video? Or use one band for both after selecting the channel?
I wish to extend the video reception in urban areas, and if I can extend flight range then great. In urban areas (where legal) I am getting 250-300 meters max in the USA. Rural mountain tops I have ranged almost mile (1.25km?) and not pushed it to limit, that has been enough for me.
Is modding the drone with different antenna(s) needed or just the controller?
So I am thinking:
Helical or circular polarized (FPVLR) on at least one antenna lead on the controller (both?) vs an Itelite DBS....2.4ghz. But my understanding is that circular polarized antennas are Right Hand or Left Hand and would need a corresponding antenna on the drone to properly receive, is that correct? So that would dictate a birdseed antenna mod, yes? The Anafi has double band antenna(s) in each leg. So I am assuming each leg is directional and in totally ar omnidirectional, so maybe a birdseed mod is not necessary....unless these are not compatible with a Right or Left hand circular polarized controller antenna(s).
Also is it safe to assume any antenna designed for the MavicAir to be compatible with the Anafi, seems like same technology?
Apologies for my ignorance. I would like to perform baseline ranges measurements before modding antennas and share results here.
So advice is needed and appreciated! The only real shortcoming to the Anafi IMHO is range. This ws helpful here : ANAFI - Wi-Fi range efficiency - Parrot Blog
I did not know that turning on Airplane Mode cut interference with the controller for instance. And manually choosing 2.4ghz instead of All.
So I am thinking:
