How long does it take to calibrate gimbal?
SkyHiBaby
I've tried calibrating gimbal three times. I cancelled it each time after about 15-20 minutes. I've done it before and I'm pretty sure it only took less than a minute. Anybody know if this is normal? Thanks
Reactions: vekthor
Hello there
Check that you are on a perfectly leveled surface. The same has happened to me
and i found that the drone was not happy with the ground beneath ??
I hope it´s the same problem, fly safe
Hi Vekthor, i also have problems with calibration. I tried on various surface but Anafi doesn't like it! It still gives me the error message. On what surface did you do the calibration?
Reactions: vekthor
Hi there
At first i was trying on a table and it turned out that the table had a very slight inclination.
I opted to do it on the pavement, outside.
After several attempts i calibrated outside and used a level tool (you can install one on your smartphone if you don´t have the tool itself) to make sure the floor was leveled.
Everything worked once i found a leveled surface. I´m not sure if our experience is the same, if the problem is similar, but give it a try, i hope it works out for you.
Fly safe
Hi guys, I eventually resorted to the old standby - turn everything off and start over again, did the trick! Works now.
Reactions: vekthor
Peanut
