- Joined
- Nov 3, 2018
- Messages
- 6
- Reaction score
- 0
Hi,
Each time when I connect my SkyController 3 to mobile device by USB cable the Android showing that start process of charging of the battery of the device from the controller. Each time I try to choose other option for USB connection, but it seems that Android avoid them and return back to charging. In my opinion this action is not expected, because the internal battery of the controller should be use for flights of Anafi but not as power bank! In this case the power of the internal battery of the controller is running out faster without any adequate reason! I tried to use power bank during the flights and it is work properly, but the indicator for internal battery of the controller showing always 100%, which can not be correct.
Some suggestions how to avoid using the battery of SC as power bank for device?
