Jello problem
Nexus
Hi Guys
I have jello effect on my bebop 3.0 live video and recordings
After investigating all the damper shafts and damper bushes are like new and undamaged the frame and electronics plate is undamaged
But on removing the props and checking the motors by attempting to rock them for play, all motors shafts rotated freely and were not bent. On checking for play in the bearings 3 of the bearing had the normal amount of freeplay as expected..
But the front right motor had far more play than the others and could be rocked by the casing. On removal of the motor the C Spring washer had moved down the shaft by maybe 1.5mm. Upon putting it back in the correct shaft groove, normal play like the other motors has been restored.
Is it likely that this was the cause of the Je;llo on my video and recordings? I checked all the props and they are all genuine parrot and free from damage or defects.
Many thanks for any replies
lustar
