I found an old laptop cooler at a discount store it is aluminum and has dual 5v fans. I use this when updating to keep the anafi cool when updating or working on it indoors while it's on. You can use something hard to sit the drone on but if it's soft it will just sink someewhat and won't get good airflow to the brains. If you have one of those notebook coolers you could even take it to the field and run it off a 5v usb powerbank. Put it on a tripod to keep it high off the ground and blowing debris into your anafi. Use this indoors or in hot climates. There are some out there with more than 4 fans. Heck remove battery and put your drone in the fridge or freezer before you fly. JK.
Was going to post this in the summer but would have forgotten to post.
