Hi m8 the map preloads at home fine and I can see saved maps while in the fields but when I load them it's just greyI have to pre-load maps before heading out because the phone I am using does not have active service. Only will connect to the internet by wifi. As long as I preload the area I will be in, I have no problems displaying them while flying. Did you set the map to display on screen?
Mike
I have it set to display hybrid map, I've a feeling it might be something to do with the net mabye a wireless thing? Thank you for your help ?I only have the option to preload maps, not display a saved map, other then when I am flying. The map comes up automatically when I launch the drone. Do you have the settings to display the map in the interface settings?
Thank you Mike ill give it a go and let you know ?When your using your phone for flights, you want to turn wifi off and turn airplane mode on.
The phone I am using is a never-activated Tracphone, it has no cell service, its basically like a small tablet. I can pre-load the maps at home using the wifi, then I turn it off.
I have gone places and realized I didn't have the map for the area, in that case i tether it to my cell phone and download the maps. Then go flying.
Mike
