Max altitude 150 meters limit - Anafi - 1.6.0...
julientaming
Good evening guys,
Just a quick thread about the 150 meters limit. So my Anafi got the firmware 1.6.0, I jumped like a kid when I saw that the limit was removed, get outside and fly up to 150 meters, then the drone refuse to get higher, even with geofence on Off, slide up to 4km. I used an iPhone 7. Upset, I tried with my old rooted Galaxy S4, with the official app, and miracle I can go much higher than 150 meters.
Conclusion, this trick is maybe only with Android devices, with or without FCC mode.
Apparently, on 1.6.1 is still the case. Can someone check it for me please ?
Would be nice !
Maybe we could keep a thread like that for each update ! Parrot could put back the limit at some point !
you nned to specify the FF6 version .
Its the FF6 version that has the altitudes restriction off ,
the drone 1.6.1 and the SC 1.6.2 doesn t change a thing in the altitudes ,
Oh ok, I was using FF 6.6.1 on both devices, on the android version, geofence I got max distance 100 meters, which is weird, as I can go a lot more far.
Batman
