- Joined
- Jul 30, 2019
- Messages
- 13
- Reaction score
- 5
I've used MS ICE to stitch together 360 pictures for a couple of years.
Today (March 14th) when I was trying to stitch together a few 360 panoramas I took over the last couple weeks I found that MS ICE would sometimes fail to stitch together the 42 images taken, and at other times MS ICE would only successfully stitch together a subset of the 42 photos.
(e.g. 31 of 42 images, with a Vertical coverage of 141 degrees instead of 180 degrees.
In efforts to use the 42 images, I have been trying to determine the correct 'Structured panorama' settings within MS Image Composite Editor.
Important parameters being:
a) Image order Serpentine or Zigzag (seems to be Serpentine)
b) Number of Rows and Columns (seems to be either 7 Rows & 6 Columns, or 6 Rows & 7 Columns)
c) Overlaps, including Horizontal, Vertical, 360 degree seam, Search Radius (no clue as to these)
Reviewing recent photos It seems that my Anafi is starting its' path from straight down, and then next picture straight up, then next picture a bit down, then a bit more down, until straight down, rotate, repeat..
This seems to be different from previous 42 set panoramas I've taken before the 'increase speed of panoramas' update.
Now to the questions:
1) Has anyone determined the route/path the Anafi follows when taking the 42 pictures for a 360 panorama?
2) Has anyone determined the other parameters that result in the best 360 panorama using MS ICE?
Any help greatly appreciated.
Bonne journée! = Have a great day!
