I as well.I am not talking about the AI version. Question is about Anafi_4k
I think you mean sonar and not motion because its too dark fir verticak camera to work at night. And has attitude you are referering ti the magnetic compass?I as well.
Also the old Anafi has attitude and motion sensors.
No, I mean what I said.I think you mean sonar and not motion because its too dark fir verticak camera to work at night.
I know exactly what I'm talking about.I'll be honest I really don't think you know what you are talking about.
Ok, I'll try.You dont name the sensors you just refer them as motion sensors....
Thank you for the clarificationOk, I'll try.
If there is no GPS:
1. Anafi's vertical camera is used for horizontal stabilisation (right/left/forward/back), as long as it's not too dark and Anafi is flying not too high above ground. And: this may not work over water or low contrast ground.
2. The ultrasonic sensor is used for vertical stabilisation (up/down) only at low flying altitudes (a few meter). This will work also at night.
3. The barometer sensor is used for vertical stabilisation at any flying altitude. It is set to zero at each start.
4. Each drone also has attitude and motion sensors. So does Anafi. They help to hoover wherever you don't touch the sticks and to move without tilting ...
The Anafi (like any drone) has:I think your are confusing #4 with what is called a gyro and magnetometer...
But anyway cutting through the BS...
It looks like there are plenty of sensors that take place of the vert cam at night. When it cant be used.
I think, that could perhaps work, but really don't know.Interesting if vert cam may work good at night if it can sense street lights or ground lights to use as a reference. Opposed to farmland with no lights
