One blade is not turning
oldp33
Hi there,
We've spent the afternoon updating our Mambo's Firmware and finally got it updated to the latest version..only to find out that one of the blade is not turning when trying to take off...It's not firmware related (it was already the case when the drone was last used) but related to a landing in high grass...Took the blade out, stick some masking tape on the axe, just to figure out that it is not turning either..What can we do ?
Thanks for your help !!
Olivier
Try this: Remove the propeller clean the engine and put it again, if this doesn’t work you should change the engine this video will be helpful
Reactions: mrajic
dronemotion
