parrot anafi gimbal problem
Landan
Hi i need help i crashed my parrot anafi and i believe the L bracket broke can anybody post a pic of the L bracket so i know what it is and does anyone know where i can find one online ?
Thank You, Landan
Not the easiest part to get hold of. Your options are limited to:
  • Checkout eBay for someone stripping an Anafi for parts.
  • Checkout Classified section of forums for users stripping Anafi for parts.
  • Strip yours and sell it for parts and replace with new Anafi from what you make on parts
  • Strip it all done, and being very careful see if you can use some bonding agent to put it back to how it should be.
If you attempt bonding it back together, double check and double check again, that everything aligns correctly, before bonding.
Probably not what you wanted to hear. The only other option would be if you could prove there was a fault that caused you to crash, and that's assuming the device is still under warranty, and Parrot want to play ball (unlikely)
HTH
Ill take it do you have pay pal if so can i get your information so i can send you a payment
