Password recovery
Rocky the FS
Hailey, ID
I can't seem to get the wifi password to work, so I tried the reset procedure. There was no txt file created with the original key. Has the reset procedure changed?
Did you follow this exactly?
1. Power ANAFI on.
Yes, exactly. I first let the Anafi complete its initialization. There did not seem to be any evidence of rebooting, either (camera gimbal, prop movement).
I believe the reboot part is what will generate the Text file so if it is not rebooting that would be your problem.
I just tested mine. It is all up to date. Just turning on the Anafi and let it go through its checks I then held the power button until all four LED lights lite up. As soon as the last one was lite I let go of the power button and the Anafi rebooted. The end result was a wifi_security_key.txt file. So yes it still works at least for me.
It worked this time. It's extremely sensitive to just how fast you let up on the button. I have always had trouble figuring out the password, whether it had a capital I or a capital O or a 1 and a 0. So I opened the *.txt file in an editor and changed the font to Times Roman! It's a capital I and a zero. :)
Reactions: Jagerbomb52
gearsgood
