For new owners, just a copy & paste from my post in this thread Anafi USB port/On-Off switch assembly pictures, as I'm convinced many breakdowns happen because of the USB socket on the Skycontroller3.
I bought a brand new Anafi not long ago, and the controller was already out of order. The USB socket to connect the controller to the smartphone/tablet is not well designed, it's too easy to break this part just by putting the controller down. A few photos to illustrate the advantage of a L shaped USB plug :
Straight USB plug, most weigth applies on the USB socket
A 90° L shaped plug is clearly less problematic, less pressure on the plug itself (and so less on the electronic board inside, which is a common issue)
You can find L shaped USB cables with even smaller heads than this one, a few bucks only on ebay...
