problems with alienteech pro antenna
Horacio_marin
Good morning, greetings from Chile.
I tell you that I have an anafi parrot and I bought the famous alientech pro 5.8g antenna and I had no problems installing it.
the problem is at the time of volor my drone. i do the following
-I take my anafi drone
-o open the control and connect x usb cable to my iphone
- connect the drone to the control
-the type of network is in automatic.
-I take off my drone and lose connection at a distance of about 5 meters.
If someone has happened to help me, I would really appreciate it.
greetings and take care
This sounds to me a bit like the antenna itself IS NOT connected, at all.
You are saying, you got the 5.8 GHz antenna. Is your bird/RC running on 5.8, manual?
Take off the antenna and try without
Check this way, if you are not only "running" on the antenna cable, for instance.
In case you are on 5.8, but the result with/without the antenna is the same, contact alientech
changed to manual for network with 5ghz bro
gearsgood
