Hi.
Yesterday I changed some propellers (the rear ones on the right) because they had some damage and the Anafi when starting up two feet off the ground and turned on the leg of the new propellers. I thought I was confused with the propellers, but I checked them and they were the right ones for that side, and the screws were not loose or bad. With the blow the tips of the new propellers wrinkled, so I put on another propeller but the drone does the same, starts to turn well but after 1 or 2 seconds it makes a strange noise and much stronger than normal ( it seems that of the other engines, not of the one that takes the new propellers) and it is defeated towards the right rear side. I calibrated it every time I changed the propellers.
That could be happening? Has the same thing ever happened to you?
It occurs to me to change all at once, but I do not know if that will fix something.
regards
regards
