- Joined
- Mar 8, 2020
- Messages
- 5
- Reaction score
- 0
Anyone else have this issue? There is no longer any tension on the rear left leg. Is it an easy fix?
Thanks. NO fall whatsoever. I have babied this baby. Just seems like bad construction.If it is new, request immediate replacement.
Especially if there has been no fall.
Thanks,mrajic. SInce I got mine renewed from an eBay seller, it looks like I may have to go this route. I did find the Parrot Anafi Drone OEM Hinge Assembly on Amazon. It may be wise to invest in a few!Check out this thread, you might find it helpful:
Rear arm won't lock open
I took delivery of my Anafi just days ago...bear with me on this: I had it out on a flight and it bumped a tree. It not a hard crash and nothing was broken. I picked it up, looked it over, and went through the calibrations again (which went fine), and made sure everything worked: Crucial to this...parrotpilots.com
Luckily I was able to return mine JUST under the gun-right AFTER ordering the hinge assembly. I did end up ordering another (Anafi) afterwards (for a slightly higher price). I ordered it here:Did you manage to get the replacement hinge? I am in need of one but the link on Amazon says it is no longer available. I don't want to buy the whole repair kit for £89.99
That product is not available anymore on that linkLuckily I was able to return mine JUST under the gun-right AFTER ordering the hinge assembly. I did end up ordering another (Anafi) afterwards (for a slightly higher price). I ordered it here:
So mine is on standby in case I run into the same issue with the new one.Amazon.com: Parrot Anafi Drone OEM Hinge Assembly : Toys & Games
Buy Parrot Anafi Drone OEM Hinge Assembly: Quadcopters & Multirotors - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
That's odd. Maybe because you are in the UK? (Just assuming since you quoted a price in pounds sterling above...) I am in the US and am able to add that item to my cart on Amazon, right up to placing an order. Regardless, the eBay link provided by Miningnew appears to be the right part (even if it is called Motor Axis Part 11). And it is still available for considerably less!That product is not available anymore on that link
I have a similar issue on my brand new Anafi. Thermal. Parrot has Authorized me to open & check or they will provide free replacement. I learned after opening that the white 3D printed hinge is the main problem. I think it is a quality issue. I also believe this is one main reason for Anafis to fall from the sky especially during hard maneuvers.That's odd. Maybe because you are in the UK? (Just assuming since you quoted a price in pounds sterling above...) I am in the US and am able to add that item to my cart on Amazon, right up to placing an order. Regardless, the eBay link provided by Miningnew appears to be the right part (even if it is called Motor Axis Part 11). And it is still available for considerably less!
Any idea where to get them. These hinges have failed considerably.There are no 3D printed parts - the hinge parts are all injection moulded.
If I purchased a new Anafi thermal that was faulty out of the box - I would not mess around with it and just send it back for replacementI have a similar issue on my brand new Anafi. Thermal. Parrot has Authorized me to open & check or they will provide free replacement. I learned after opening that the white 3D printed hinge is the main problem. I think it is a quality issue. I also believe this is one main reason for Anafis to fall from the sky especially during hard maneuvers.
Now if a smart fellow with a 3D printer managed to scan that part and start printing them I think he could make a buck or two
Ok..latest update.. I send my new Anafi thermal back to the distributor . They will send me a new Anafi thermal. It looks like they don't have a spare hinge )Yes , I agree but they allowed me to open. Seems like a good distributor. They said they can replace if required as well.
