Remove and reinstall Freeflight6
Thanev
Alberta,Canada
I would like to remove and reinstall Freeflight6,as I have updated twice,and feel a clean install is in order.
Once I have reinstalled,would I have to rebind to the Anafi,or would Freeflight6 just start right up as normal once I connect via cable to the controller.
As long as you are using the controller all you will have to do is sign in to your parrot account. Have reinstalled app a few times with no dramas.
Reactions: Thanev
maybe RTH altitude, max distance, max altitude should be set before flying.
bandy
