Replacing motor
Peter b
How difficult is it to replace a motor on a bebop 2? Which video is the best?
Not that hard. Just make sure that you attach the correct orientation.
A=anticlockwise, C=clockwise.
3 screw attach to the mast and 1 screw for the cap. Test Without propellers of course.
rule of thumb, if there is significant resistance then it is faulty. It should turn/spin with minor resistance. Just like the others.
YouTube has very good videos.
Actually it's 4 screws to remove the foot...two screws to remove the power plug then three screws to remove the motor..just use needle nose pliers and gently pull the plug from the connector. DONT PULL BY WIRE! The motors are labeled on the connector A or C.
Peanut
