Drone and controller updated. Reset and re-calibrated both. Flew a few minutes : no problem noticed.Seems to be a new update so please report any problems here. So far I have not seen what the update was for. Perhaps just bug fixes View attachment 2274
You mean: recorded on my.parrot ?Hi there
Can you please confirm if your flights (flight logs) are being updated as you fly?
Thank you ?
Have checked : for me, it's OK. Flights keep on recording on My.Parrot and displaying on FF6. Datas also available on Flight Data Manager.Hello
Yes, recorded both on my.parrot and displaying on the freeflight6 app.
I´m currently trying to solve a problem with Parrot. My flights don´t update since 04 May 2019. Seems i´m not the only one.
There is a thread about the problem.
Thank you, fly safe ?
Hello
This issue (also described in post #6) cannot be caused by this update, because the problem obviously already began in May.I have the same problem.
Modded fcc apk still works? if you use...Update installs without problems. First flight without problems, some photos and a video ok as before. Flight range no changes. Flight is logged.
So I don't know what this update does. No release note until today for this update.
If parrot upgrade the firmware of the drone and the controller to setting the fcc based of the gps drone and not smartphone/tablet gps, forced apk fcc dont work anymore. I hope parrot not modify this setting.There was no update to the App so I see no reason it would not still work as before.
If that was the case I am sure someone would have complained already. So far I have not seen anyone mention problems with the modded App.If parrot upgrade the firmware of the drone and the controller to setting the fcc based of the gps drone and not smartphone/tablet gps, forced apk fcc dont work anymore. I hope parrot not modify this setting.
Perhaps hoping it fixed the problem?That's what a lot of firmware updates do,right?But alas,I was mistaken.This issue (also described in post #6) cannot be caused by this update, because the problem obviously already began in May.
So why do you (and vekthor) post this issue here in a thread about problems with the v1.5.6 update?
You're not alone, I think all Anafi owners are the same.Hello everyone,
Since update 1.51 I have a problem with the wifi signal, the wifi icon in the top right of freeflight 6, just next to the drone icon, always remains with the maximum signal, it never changes even when the red message tells me that the wifi signal is weak.
I installed and uninstalled freeflight 6 several times and tried it on 2 different remote controls and 3 anafi drone and it's the same.
Do you have any ideas?
I have contacted Parrot, I am waiting for an answer (sorry about my english)
