- Joined
- Aug 15, 2019
- Messages
- 512
- Reaction score
- 388
Went out for my normal lunch time flying and ended up losing the Anafi. Totally my fault, and a combination of errors on my part.
Events happened as follows :-
1) sent the Anafi off on a flightplan - maintaining VLOS as normal.
2) A few wifi signal errors popup - normal as I am around 400-500m outs.
3) First ERROR on my part - Geofence reached error pops up on controller while excuting the flightplan. I have my geofencing set at 500m and it turns out my flightplan was taking the Anafi out to around 550m from me! and guess what I do not have VLOS on the Anafi due to a couple of trees which from my elevated position are still too tall for me to see it!
4) So I quickly go in to settings and adjust the Geofencing to 1Km
5) Lose video feed and signal - so I wait for the expected finish time of the flightplan and I see no Anafi in the sky.
6) Second ERROR on my part - I hit the RTH button a few times - wait a few more minutes - still no Anafi.
7) Third ERROR on my part - I decide to try and walk to the last position of the Anafi before I lost contact.
8) Hard to explain but the walk to the location takes me around the site rather than directly to where the last Anafi position was, so around 15 minutes long walk.
9) While walking round I get a signal and video feed on the controller and looks like the Anafi is near some bushes and being moved around with the controller saying unable to take-off. And the position - back at the RTH point.
10) I rush back to the RTH point and sadly no Anafi!!
So my take on this is that when the Anafi hit the Geofencing limit - it stopped and just hovered awaiting instructions, by that time my controller had lost connection with it - so it did not get the updated geofencing commands.
Then I started walking around and at some point when I was near enough the Anafi received the RTH command or the Anafi executed an low battery RTH.
The Anafi went back to RTH - it either landed in some bushes (I looked and could not find it and unlikely), or as I suspect it was STOLEN as I took off from a footpath/trail! It took me over 15 minutes to get back to RTH!!
The takeaway from this was, I paniced and jumped to the conclusion that the Anafi decided to plunge to earth - where as if I had stayed put it would have RTH when it hit low battery and I would still have the Anafi !!!
