Can I use a non SkyController 2p wall charger(regular bebop2) to charge the 2p controller? I know it has the Li-Ion, but heard that the charge circuit was built in and all it needs is 12v. This true?
Yes, but you need to know the plug + and - so check two times before you build yours normally they are negative outside in the big metal areaCan I use a non SkyController 2p wall charger(regular bebop2) to charge the 2p controller? I know it has the Li-Ion, but heard that the charge circuit was built in and all it needs is 12v. This true?
Bebop 2 power or Bebop 2? Maybe the charger rate or voltage is too highI charged the 2p liion battery out of the sc2p. When I put it in it reported only 85% on my sc2p. But 100% on my external charger. Should I have used a lipo setting instead? External charger never reported done just Full message.
