Tablet sucking power from controller
seawolf9844
My Hoozo tablet appears to be using the controller as a power source. Micro USB plugged into tablet and using the USB-A port on controller. Does using the USB-C port on the controller change this phenom? I do not find a setting on the tablet to stop sucking power.
Sent from my SM-G970U1 using Tapatalk
Very common with Android systems. Not much you can do other then modify a cable to stop the power draw. The power it takes is not that much IMHO but a member on here has a modification for the cable to help the problem. I'll see if I can find it.
Reactions: pmh1nic
If you start reading the posts from this thread you can find a solution.
lustar
