New to flightplans -- If I understand, waypoint altitudes are relative to the starting point? If so, if you're starting at a high point (on a mountain top), how can you set a negative altitude so waypoints can be downhill from the starting point?
To make a flightplan with a POI lower than the launch altitude, I have got this method working. I have only tried this on Android. Obviously I can't guarantee this is 100% safe but I have tried it successfully. 1. In the internal storage area of your phone (where your file manager lets you see...
The instructions in the above topic are correct and work flawlessly. I fly my drone in the mountains and routinely run flight plans with waypoints below and (often 2,000 - 3,000 ft.!) above the start point. This is legal as the drone stays under 400 ft. AGL.
