I got the Sandisk Ultra 400 GB and the Sandisk Ultra 256 GB working in my Anafi yesterday by following this thread (it’s one of the stickies). SD Card Format Issue - SOLVED!Cool, thanks very much!
With the ANAFI I wouldn't recommend switching in and out micro SD cards. The holder is pretty fragile and you are going to break it eventually. Stick to a 64GB or 128GB card and you will have plenty of capacity. I would recommend downloading the video to a computer regularly. Once the memory card gets full on the drone it will slow down the performance a bit. And like previous post said, you can lose everything on the card at any time if the drone crashes in a lake or something.I would not recommend to put a huge card in there. The price doesn't scale well with the capacity, and also if you lose the drone, all the footage will be gone as well.
I bought a couple of 64GB cards, I rarely fill it with 1 flight session, but if I do, I have others to put into the drone, and the footage on the full card will be safe with me.
I disagree with this statement. I have had my Anafi for over 2 years now. I remove the card after every flight to down load my videos or photos to my PC. Never a problem. This type of SD card holder has been around for ever and works well. You can order new flippers\locking doors if you happen to lose yours out in the field. I carry 10 spares with me but never had to use them.With the ANAFI I wouldn't recommend switching in and out micro SD cards. The holder is pretty fragile and you are going to break it eventually.
