I seeeee! If you measure the unloaded voltage out of the top of the charging brick the voltages are all over.
EDIT: looks like the BMS is in the stock battery. Which is bad engineering, it is adding weight to the drone. Even worse though aftermarket batteries don't have a built in BMS.
