Xiaomi red mi note 8 pro incompatibility with Free Flight 6
dkokki
Good evening guys,
anybody has incompatibility with red mi note 8 pro ?
The monitor is freezing with the app.
I have the same problem. I use my Redminote 5 with Freefligh
I realized that on the TV application, MyCanal, the image is alsos lightly is freezing .
Is there a problem with the video stream on this Redminote?
Anyone have a solution?
Zizag84 wrote that Note 8 is not compatible:
I use a Xiaomi MI A2 Lite, this one works fine.
But I can't help to solve your problems..
Good evening guys,
Since the inception of xiaomi itself, it has rewritten its Android called MiUI. It's not just a skin on the android. This system is very good but some applications do not like it.
It might be time to find a custom rom, I can't quite remember but is there an option to lower the resolution of the fpv stream if so that may also solve the problem.
I use a Mi 8 with FF6 and it works well except for sharing My flights.
I get no app options when I try to share My flights.
Reactions: JCamilo
[CITAÇÃO = "dkokki, post: 28181, membro: 2332"]
Boa noite gente,
alguem tem incompatibilidade com o red mi note 8 pro?
O monitor está congelando com o aplicativo.
obrigado
[/CITAR]
e I also have the same problem of locking and some functions do not work, but I tested it on a redmi note 7 with miui system and it worked perfectly, I believe that the problem is more than hardware
Exactly the same thing happens, on my Redmi note 9. Any ideas, to show the common shares, mail, google photos, google drive, etc. ? The problem is that only the Mi share, which belongs to the brand, appears.
I have not been able to work around this issue. Must be a Xiaomi/FF6 thing.
All other apps I have tried on the Xiaomi can 'Share'.
I have contacted Parrot, but they claimed to not be responsible, and the case was closed.
Yes, I confirm that. Parrot is now only interested in the USA market. It may also happen in the American model Anafi, if the Americans can use the Xiaomi !!!
Viking
