Alternative Bluegrass batteries?
bcow
So I got my Bluegrass as an insurance write off, as it was damaged in the Ahrtal flood (germany) in 2021. With extensive cleaning and a little bit of soldering and some 3rd party spare parts, I was able to revive it. What was damaged beyond repair of course were the 3 batteries, as the moisture created a permanent short.
So after repairing the drone I ordered a pair of cheap 14.8V batteries (20€) and a Y-cable to use the capacity (see attached pic), to be able to begin (flight) testing. Since then I am searching the internet for proper replacement batteries. Recently, I noticed there are bluegrass batteries from Gifi, a brand which for some time was quite successful with cheap aftermarket Bebop batteries (14.8V 6700mAh Battery For Parrot Bluegrass Drone).
Can anybody recommend a good battery with at least similar specs to the original one or maybe has any other advice on batteries for the Bluegrass?
kameme
