Anafi for repair or parts...Is Now Fixed
Status
Not open for further replies.
Dronographer
I crashed this Anafi some months ago. The only sign of damage was to the right rear leg where the posts that the screws imbed were broken off on the opposite half of the arm. I should have tested the flyability of the drone with tape just as a test but did not. Replaced the broken leg with a used one from eBay, charged and did a reset on my two batteries, but the Anafi will not go through it's startup tests, the battery powers down in 4 seconds. I opened the drone up a second time, to see if any connectors were dislodged, but my 60 year old eyes are not good near field and I did not completely disassemble the bird, it is a bit beyond me. Likely fixable, otherwise great frame, arms, motors, etc. I am certain the gymbal and camera are fine, not a mark on them but... who knows. Drone only, props will be removed, no battery or controller, the original gray case WILL be included. $165 to your door.
I am in Oakland, California, but when I state “to your door” that means I am paying the shipping. Sorry for the confusion, good to clarify that for people.
REMOVED FROM SALE. I opened up one more time. The two large cable connections to the main board looked OK, however I removed and reconnected them. The larger cable was definitely firmly connected, I could feel all the connections pop loose as I peeled it off, the smaller cable opposite I could not even tell if was connected properly when I buttoned it back up. BUT SHE FLYS!!! Easy fix :)
Status
Randallt14
