Battery charging
AlexdC
I just bought a new Parrot battery for my Bebop 2. I tried to charge it but the charger blinks red rapidly. I've tried to get help from Parrot but have not been able to get through to them. I never had a charging problem with my original packs but they're not holding a charge any more. I checked the charger and it seems to work fine. I charge the controller without any problems. What might be going on? Thanks
Something about the battery it doesn't like. If you have a meter you can measure the cells and see where they are at. If its an aftermarket battery, it might not have the circuitry inside the charger needs.
Sounds like the battery level is too low for the Parrot charger. Will need to be recovered with a balance charger. I think the problem will be that these aftermarket batteries are probably as old as the original Bebop. "New Old stock"
