Cannot find freeflight 3 app anymore on google store how can I start the drone
There is a way to install FreeFlight Pro 5.2.7 on newer Android phones & tablets (10+)
I've tested this method on Android 10,12, and 13.
Download the files in the previous post then use the link below to walk you through how to move the com.parrot.freeflight3 folder to the /Android/obb folder.
To safe you the hassle I've uploaded the files to make version v5.2.7 to work.
Install the apk, then extract the zip file and copy the folder "com.parrot.freeflight3" to "Android/obb/"
I downloaded everything, extracted "com.parrot.freeflight3", but when I try to copy it to Android/obb/ it says "Couldn't copy file"
Pour vous éviter les tracas, j'ai téléchargé les fichiers pour que la version v5.2.7 fonctionne.
Installez l'apk, puis extrayez le fichier zip et copiez le dossier "com.parrot.freeflight3" dans "Android/obb/"
merci beaucoup après 3 jours de recherche, je suis tombé sur ce post, et il fonctionne parfaitement sur ma galaxie s20 5g.
Does anyone know if it still works?
I tried following the steps, but the app doesn't connect, The drone, connected to the controller with a cable, flies but I can't connect it to the app, which says "connection problems".
I'm on a Samsung a25 with Android 14
