Erratic behaviours!!
CThody
Hi. I've just purchased a Swing, and it looks great. However, after pressing the take-off button it comes into the hover then decides to fly backwards on it's own, it does not hold hover at all. How can it be calibrated? Thanks in anticipation.
Hi,most issues can be fixed by reset and flat trim....after swing is updated you should press and hold Power button in Swing for 10 second,lightswill flash red and turn back to green after reset is done...place swing on floor,open freeflight mini,in settings hit Safety then hit Flat Trim once or twice(flat trim resets all sensors,fixes issues like not hovering but moving around,flys straight up etc...make sure you are not flying swing above anything thats shiny like hardwood floor,tile floor,snow,water etc,it confuses vertical camera located next to charging port in swing and that again affects stability of swing.....flat trim should be done before every take off)
Fantastic, thank you. I've tried updating (via USB to PC) but it won't have it for some reason, but it flies OK...
